Compression and pump gas.
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
Whats the highest compression you can achieve of 92 octane pump gas?
1986 Camaro
Carbureted 305
700R4
1986 Camaro
Carbureted 305
700R4
I'm assuming you mean whats the highest compression you can run in an engine on pump gas. Usually you would want around 9.0:1 to 9.5:1. I think the later is about as high as you would want to go for a daily driver on pump gas or just on pump gas in general. After that you will run into problems.
350 TPI
Flowmaster Cat-Back exhaust
Performance Chip (am trying to find out which one)
Modified MAF
Smog equipment removed
350 TPI
Modified MAF
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
My 406 is 10.25:1 and i have had no problems. I run the crap out of it too. I think 10.25 is about the max you can go on a non-new car motor. the Lt4s were 10.8:1 but they have much better combustion chambers and can get away with more compression.
88 S10
Dropped 3/4
Dart equipped 406
12.20 @ 115.25 mph
88 S10
Dropped 3/4
Dart equipped 406
12.20 @ 115.25 mph
Car: 4
Engine: 6
Transmission: 5
It depends on alot of things...
For a carbed car with cast-iron heads, 10¼ or 10½:1 is about as high as you can go. With aluminum heads, maybe 11:1 if it's set up right. The more cam you run, the higher your static CR can be.
I have had a 400 at 10.4:1 for the last 135,000 miles. Right now it has a Comp XR282HR, before that it had a XE274H and before that a 282 solid, it has always worked OK. The other cams are a little better than the 282S was but even it wasn't bad.
What are you thinking about doing?
ICON Motorsports
ICON Motorsports
92camaroJoe
Aug 13, 2015 06:07 AM
