Washer motor
Washer motor
Ok my wipers work fine, but the windshield washers dont work at all. I've thoroughly checked all the line by blowing throw them, and all the wiring is intact.
Is it possible that i have the wrong wiper motor, because the one in there is used? It looked just a little different than my original, but the wipers work fine (kinda slow, but adequate).
Don't know if this is your problem or not, but an old, disused washer fluid pump motor could lock up from just sitting there. Mine did that a while back and I had to take it apart to free up the impeller.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The washer pump is separate from the wiper motor. You can get a new pump at pretty much any parts store and it takes about 30 seconds to replace.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 385 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Because you can always sleep in your car, but you can't drive your house.
lt1z350
Sep 29, 2015 01:50 PM
