Balancing Act
Old Jan 21, 2001 | 12:04 PM
Pro91Z's Avatar
Balancing Act
I have an 88 chevy 350 block, A ZERO BALANCE ATI balancer. Now my question is….. what flexplate would I want to buy… I called summit or jegs and told them I have a late model 350 and I need it to be balanced, so what flexplate would I need. He gave me a part number and then I asked him, “are you sure this is right if my balacer is zero balaced?” And he hung up on me… so what do you guys think? Is this an internally balanced motor? And besides having weights on them, is there another difference between and internal or external flexplate (one piece/ two piece rearmain? Or bolt patterns)?????????
Thanks for the help
Pro91Z
Old Jan 21, 2001 | 12:25 PM
ede's Avatar
ede
your block should have the one piece oil seal. if it does you need the flex plate to go with it (the bolt pattern is differant, because of the pin). the flex plate will have a weight on it because of the missing fly wheel flange on the one piece seal cranks. it's still an internally balanced engine, it's just differant. i'd guess your balancer is for an internal balance engine and would work on any SBC, but i'm not sure of that.
ICON Motorsports
1st & 3rd
Old Jan 21, 2001 | 01:36 PM
Guest
Guest
Posts: n/a
ede is right about the balancer, they are all the same. I checked this with my friend at the dealer when I picked up a new one for my 86TA, only the flywheel is different.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Giocio
Oct 1, 2015 12:20 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
