Fuel leaking in engine bay?
Old Jan 19, 2004 | 02:33 PM
sancho's Avatar
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
This is in regards to my '89 IROC.
Ever noticed how you can "see" gasoline vapors, especially on sunny days? Like if you had a container of gasoline, left the cap off, and then looked across the opening, you'd see the gasoline evaporating.
Well, I've noticed that when I have my hood open with the engine running, I can see the exact phenomenon happening. It almost looks like the engine is under water. Plus, I can very obviously see shadows of this stuff on the concrete next to the car (i.e. if I'm looking at the shadow produced by my open hood, I can see the shadows of the vapors coming from the engine bay).
The same thing happens whether it's cold or hot outside.
Is this indeed unburnt gasoline that I'm seeing? If so, is it normal to see it coming from the engine bay?
Old Jan 19, 2004 | 02:35 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I assume you see this after the motor warms up? Heat distortion. Like the road in the distance on a hot day.
Old Jan 19, 2004 | 03:51 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
If you dont smell gas then its not gas just heat.
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
