Do I still us my ECM?
Old Jan 21, 2001 | 04:32 PM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
This may sound like a stupid question I want to know incase I go back to a 700R4. I have removed all emissions and I have a non-lock up torque converter on the 350. Oh, Carb. too. If I switch Tranys soon does the ECM control Transmission lockup or anything else I am using. All gagues work.
Thx
'84 Camaro w/ Large Jouranl 327 bored .030 over; 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B&M Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
It is still under construction @ www.iserv.net~brodgers
Old Jan 21, 2001 | 10:33 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
The computer controlls lockup but vacuum kits are available for non-computer cars to lock up the converter. TCI has them, just need to run power and a manifold vac line down to it.
Old Jan 22, 2001 | 06:37 AM
Car: YTG Camaro
Engine: 383
Are you positive? This conflicts with everything I understand about Torque converters. Unless they make a Trany that controls lockup via vacume.
There allready is a vacume line and I dont think my trany is lock-up compatible.
Old Jan 22, 2001 | 08:42 AM
82camaro's Avatar
Car: 82 camaro SC
From the factory, the ECM controls the lock-up electronicly. Aftermarket kits, such as tci use an added on vacuum switch that controls the lock-up of the converter electronicly. With high vacuum(engine not under load), the vacuum switch turns on the lock-up converter. With low vacuum(engine under load), the vacuum switch unlocks the converter. The tranny is still locked/unlocked electronicly, the vacuum switch takes the place of the computer in determining when to lock/unlock the converter.
Most of the kits I've seen require modification of the internal wiring on the 700r4--it's easy to do and will allow lock-up in 4th gear only. The TCI vacuum switch is adjustable and the kit has provisions to set up a toggle switch to manually control the lock-up.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jan 22, 2001 | 09:42 AM
Macgyver's Avatar
Moroso has a kit too, I think it's cheaper.
Old Jan 22, 2001 | 12:37 PM
Car: YTG Camaro
Engine: 383
If I understand this right that means I can get rid of the computer and use this aftermarket lockup switch if I go back to a 700r4. Can anybody think of a reason that I shouldn't sell the ECM?
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
