Similar cam to LT4 hot cam?
Is there a cam out there that is similar to the LT4 hot cam. The reason I am asking is because I have an older non-roller block and the LT4 cam is a roller cam. Or does GM make the LT4 hot cam for non roller motors as well. I am looking for something that will act similar to this cam.
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
there isn't any specific non roller cam that is called the hot cam but just flip through summit or jegs and match one with the same specs. You could also have a custom one ground. If you are going carb you can get the same specs but it will most likely have a lower LSA because of its carb application.
