Heater Core-need easy way to fix
Old Jan 22, 2001 | 09:34 PM
Scottiewitdabody's Avatar
dammit my heater core when out and i got a new one but is there any easy what to replace it w/o ripping my car apart? any kind of way to clean interior from coolant leak?
Scottie 2 Hottie
Old Jan 22, 2001 | 10:25 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not too many shortcuts for that one. About the only possibility is to replace it. If you take off the dash pad and the duct on that side, you can get to alot of it much easier. It's no fun even like that, probably a 4 or 5 hour and $40 of parts kind of job for a first-timer.
ICON Motorsports
Old Jan 22, 2001 | 10:40 PM
Vader's Avatar
Scottie,
New heater core - $24.95;
Time to replace (if you take the easy way) - two hours;
Satisfaction from a job well done - priceless.
BTW - You can clean the antifreeze from the carpet with hot soapy water, followed by a wet/dry vacuum to pick up the water, then a hot water rinse, and another vacuum. Use very mild soap and very hot water. You might have to rinse/vacuum several times to get it all, but it will eventually clean out. This will probably take longer than the core replacement. Use your new heater core to dry out the carpet when finished.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Old Jan 22, 2001 | 11:10 PM
burnoutrpm's Avatar
well if you find a easyier way email me and let me in on your little secret! trust me i thought i found a easy way but it wasn't just face the problem and dig in and do it! if you work hard!?? you can do it say 3 or 4 hours!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 intake.
Future mods performer rpm air gap intake (polished) and 600 edlebrock carb, comp roller cam, and way better headsa 400 defintely in the works!
Old Jan 23, 2001 | 06:07 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Here is a few tips here: Heater Core
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
gta892000
Aug 11, 2019 11:16 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
