Fuel system pulsating...why?
Old Jan 22, 2001 | 12:25 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
Well, maybe this is related to the detonation problem, but the fuel supply line pulsates, you can hear it and feel it. Seems worse at the regulator instead of back at the tank.
When I changed to an adj fp reg, it stopped until I drove down the block, and it started pulsating again.
I assume its pulsating because the pressure is dropping and rising very quickly.
It seems to pulsate at the speed of the rpms, gets faster as the rpms get faster.
Fuel pressure seems to rise like it should during accel, but needle vibrates real bad.
Any ideas on cause?
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Old Jan 22, 2001 | 04:35 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
It may be the fpr diaphragm iself. Do you have a guage? If so, check your pressure at idle and report back. Also, rev it a few times to see what the pressure does then.
89 Iroc-Z LB9 TPI auto 2.73 posi:
3" Dynomax muffler, K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, accel 300+ wires, cap&rotor, synthetic oil, flexlite transmission cooler, afpr, !air pump&diverter valve, kicker sound system, soon to attempt engine swap...
Old Jan 22, 2001 | 06:43 PM
2QUIK6's Avatar
Base pressure with line off is set at 50# (see detonation post is why so high) at idle its around 40-42#, and climbs accordingly to around 48-50# at WOT.
I installed a new diaphram and spring when I installed the adj. reg. this last weekend, and it stopped pulsating for about a block down the street then it returned.
Old Jan 23, 2001 | 04:01 PM
2QUIK6's Avatar
Any other ideas?
I have also disconnected the return line at the manifold at idle in case there was a return line restriction, but no change.
[This message has been edited by 2QUIK6 (edited January 23, 2001).]
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
