Will vortech fuel rails work on the Miniram?
Old Jan 23, 2001 | 04:54 PM
87z28's Avatar
Seems like this would be sweet, seeing as how they only cost 145 compared to TPiS's 300 dollar rails. Any thoughts, or any other , cheaper, sources for miniram compatable fuel rails?
P.S. it is my opinion that the stock fuel rails not fitting on the miniram is just another conspiracy to get money from us. If they designed the whole thing why, oh why, couldnt they get it to work with the stock logs? Anyway...
Old Jan 23, 2001 | 07:07 PM
GMI FAST's Avatar
You can't use Vortech rails. It's no conspiracy, they design the intake to make power, then design fuel rails later. I used LT1 fuel rails I had laying around the shop (free) and welded fittings on the ends for my braided crossover. Then I used 2 small washers as spacers to keep the rails from smashing my injectors when I tightened them down. I even used the stock LT1 mounting holes. The rails fit! Injector placement was the same.
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 406" Bow-Tie NASCAR Tall-Deck, Accel Pro-Ram, DFI, AFR heads, HRC T76 Turbo, NOS 150-hp dry kit, TH400 w/GV overdrive, 12-bolt w/3.70 gears, 8-pt. S&W rollbar, Spohn suspension, 18" wheels, Baer brakes
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
wayshegoes
Aug 17, 2015 12:00 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
