Anyone running mid thirteens with an L98, what mods?
Old Jan 22, 2001 | 07:30 PM
87z28's Avatar
I'd love to hear your combo. I'm looking to run mid thirteens in my 91 Z-28 and I want to have a look at some "recipies". Thanks, and keep 'm comming.
Old Jan 23, 2001 | 01:29 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Check the link in my sig.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 23, 2001 | 01:46 AM
JERRYWHO's Avatar
Forget the 13s get the spray and run 12s all day.
92 Z28 5.7 TPI AUTO 105k factory motor and trans.
SLP headers and runners, B&M 2400 stall, shift kit,LCA brackets, EIBACH spring kit, NITTO'S, N.O.S.
best 60ft 1.84 1/4 12.48 @ 110.81
Old Jan 23, 2001 | 02:07 AM
Dan87IROC-Z's Avatar
My mods in my signature (with the cam) and along with a set of 3.42s I should be in the mid 13s at sea level, mid 14s up here.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 3.08:1 Rear End
Current Mods: LT4 Hot Cam, Comp Cams 1.6:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Gutted Catalytic Converter, Performance Resource Chip, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, Ported TPI Plenum and Base, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Old Jan 23, 2001 | 02:58 PM
87z28's Avatar
I guess I should have been more specific of my combo. I want to run the number naturally aspirated and with the auto tranny. Thanks.
Old Jan 23, 2001 | 04:25 PM
irocbsa's Avatar
In the sig you will find your answer......
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jan 23, 2001 | 07:51 PM
88 IROC BOB's Avatar
Look below for times and mods. I'm in the high 13's with just that. This year there will be a Vig 2800 stall convertor and a new intake and runners.
Should be in the mid 13's with these for sure!
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Vintageracer
Jan 10, 2020 05:33 PM
TheJoeY88
Dec 31, 2016 07:30 PM
TheExaminer
Aug 19, 2015 10:07 PM
mdtoren
Aug 16, 2015 05:45 PM
matthew911
Aug 12, 2015 09:38 AM
