Compression Test?
Old Jan 22, 2004 | 01:30 PM
Gambit69's Avatar
Car: 1989 Pontiac Firebird Formula 350
Compression Test?
I am wanting to know how I can do a compression test on my car to see if I might have a small leak in my head gasket. I dont seem to be loosing any antifreeze I just notice some bubbles that are staying in the radiator. I have some leak sealer in there that I put in there quite a while ago and I don't know if with this in and the flow of the antifreeze through the engine is causing it to bubble or if there is a leak around the exhaust part of the head causing some air to leak in. If anyone can help please let me know.
Old Jan 22, 2004 | 02:27 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
do a search, u will find the answer
Old Jan 22, 2004 | 03:38 PM
ede's Avatar
ede
remove all the plugs, open the throttle plates, screw compression adapter into cylender attach to gage, turn key for few seconds, maybe 10. record readings amd compare. you can also use an combustion gas detector at the radiator or over flow tank. actually using both is a good method, sort of a fail safe method.
Elephantismo
Feb 13, 2019 12:51 AM
FormulasOnly
Jul 23, 2018 08:47 AM
NZKnight
Oct 15, 2015 02:47 PM
RedLeader289
Sep 23, 2015 06:50 AM
WhteRbt
Sep 21, 2015 09:48 AM
