EGR operation??
Old Jan 23, 2001 | 04:07 PM
2QUIK6's Avatar
Car: 89 Turbo Trans Am and lots of non-3rd gens
Engine: 231 SFI Turbo's, LT4, LT1
Transmission: 2004r, 4L60E
EGR operation??
Just wondering how the EGR "should" work given the way it was installed.
Mine is not controlled thru the ECM, it is just hooked directly up to a vacuum line.
So given that, shouldn't that make the EGR valve OPEN during idle since that is when there is the highest amount of vacuum?
I am not having any idle problems, and I can manually push up on the diaphram and it causes the engine to run rough and almost die at idle. So is it not working?
I know this is not the way it should be hooked up, but FIS put it on that way to try to get rid of the detonation problem at cruise and light accel.
Rob
High Performance & Party page
Pics of my rides past & present and recent party pics!
89 TTA #426 20th Anniversary turbo 3.8 bone stock
94 Silverado Tuned Port Injected
87 Grand National- lil' ole V6, highly modded
95 Trans Am Conv.- LT1
Old Jan 23, 2001 | 07:48 PM
gruveb's Avatar
Car: 1989 IROC-1
I'm a complete novice when it comes to EGR. I was hoping that you could tell me a little, since you already know more than I do. What exactly does the EGR do? What would happen if I took mine off? The person I bought the car from has the emissions totally screwed up. The car runs fine, but the air pump is completely disconnected, the vaccum lines are very rigged and the check engine light always comes on.
I live in a place where there are no emissions checks, so that's not a problem.
What do you think?
Old Jan 23, 2001 | 07:53 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
First of all, very few engines actually have a vacuum line straight from the intake to the valve. Even at that, they are ported vacuum (vacuum above idle) and they are backpressure valves, so it does not open at idle. Which car/engine do you have? All thirdgens have some sort of EGR solenoid.
As for EGR theory/operation, check this link out: EGR
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 23, 2001 | 08:07 PM
2QUIK6's Avatar
This was on a 92 TPI setup with all emissions removed, physically and from the ECM. The EGR was added this way to see if it would reduce a detonation problem, but it hasn't. It is hooked to the vacuum line that is located on the bottom drivers side of the TPI throttle body, maybe this is one of those vacuum ports that does not have vacuum at idle?? That would explain it, so it must be. Thanks.
Old Jan 23, 2001 | 08:52 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
I found it amazing that even if you block off the EGR the motor still gets some. In the base there is passages milled into all the runners (like a 1/4" hole!)
Old Jan 23, 2001 | 09:39 PM
93ND500's Avatar
2QUIK6, That is the ported vacuum port. There should not be any vacuum on it at idle, that's provided the idle adjustment screw is still at the factory setting. An easy way to tell is to remove the top TB plate. You will be able to see where the throttle plate blocks off the port when at an idle position.
1993 C1500 Indy 500 Edition
1992 TA TPI setup
Stock motor, new one being built now.
www.geocities.com/wsleigh
Fanatic1074
Oct 3, 2022 05:57 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Royal_Z
Sep 30, 2015 08:45 PM
