Orange on the Plugs??
Old Jan 23, 2004 | 10:07 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
on the very very tip of the plugs, i have orange. it almost looks like rust! its on 4 of them...
2 of those 4 are also black on one side, white on the other. sorta melted looking too... i assume i ran into some detonation and replaced them of course.
but wheres the orange coming from? never seen bright rusty orange on the tip of a plug before.
Also let me add the fact I have not run N20 on these plugs..
and these are AC Delco 5's. long style for my heads.. Indexed for the flame front.
Old Jan 23, 2004 | 10:54 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
if it was a LIGHT orange flaky deposit then it is detonation.
if its darker orange red color to the plug itself then it could be fuel additive or winter gas doing it.
BTW if the plugs are colored TAN it is good.
Old Jan 23, 2004 | 06:44 PM
Damon's Avatar
If you got black on ONE SIDE of the plug's porcelain then it's almost certainly oil coming in through the intake valve (bad valve guies or guide seals).
Wanna know for sure? Put a magic marker line on the outside of the plug that's in line with the black mark on the porcelain electrode on the inside of the plug. Put the plug back IN THE SAME PLUG HOLE IT CAME OUT OF and tighten normally (or this test will be meaningless). Does the magic marker line point at the intake valve for that cylinder? I bet it does.
Oil has a much lower octane rating than gasoline. If you're marginal on detonation to begin with this slight oil consumption could be causing detonation on those affected cylinders.
Old Jan 23, 2004 | 06:55 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Orange will also show up if you using to much octane.
2 gal motorcycle tank, half a can of 104+ that does 22 gallons
= plugs so orange they look tasty.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
skeltor
Feb 2, 2016 10:37 AM
89 formula TPI
Oct 6, 2015 08:40 PM
89 formula TPI
Sep 7, 2015 11:06 AM
