Fuel Pump
Old Jan 23, 2001 | 10:55 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
Engine: 1998 L31 350
Transmission: 700 R4
Fuel Pump
Guys, how long does the fuel pump run after you shut down the engine? Mine runs, somewhere between 30 seconds to a minute. I havent noticed a fuel leak anywhere. Could the injectors be drooling into the manifold? The car has a problem running rich anyway? Somebody replaced the factory 350, with a ragged 305. It still uses the factory TPI, so I know the injectors are too big. Could that be part of it?
Old Jan 23, 2001 | 12:33 PM
Vortex_89rs's Avatar
Mine didn't run at all after I turned the car off, both with the stock pump in and a replacement.
Vman
1969 Camaro Sport Coupe
383, 700R4, leather, everything black but the lights
Previous owner of an 89 RS Camaro
2.8L V6, 700R4
Old Jan 23, 2001 | 12:39 PM
R.O.B.'s Avatar
NC- Your not alone, mine does too, and its all factory stock. Runs rich too.
Rob
'86 TA 305 TPI
nc-iroc's Avatar
Car: 1989 Iroc-z
Thanks, I wonder could the pump be going bad. Just another thing I need to replace.
Old Jan 23, 2001 | 01:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You may have either a bad relay, or the oil pressure sender that serves as the pump's cutoff switch (for safety reasons - so it doesn't continue to run after a wreck or something and start a fire). In either case it's not the pump's fault which is a good thing, those other parts are much less trouble to replace.
ICON Motorsports
Old Jan 24, 2001 | 09:26 AM
nc-iroc's Avatar
Car: 1989 Iroc-z
How do I check the oil pressure sender? Is it the same one that powers the gage? How much would a replacement cost? TIA.
Old Jan 24, 2001 | 10:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The relay is about $12, the oil pressure sender is about $8. Easiest way to check it is to disconnect it while the car is doing its thing, and see if it stops. Same for the relay. Or just replace it, it's not very hard. The relay is really easy, it just unplugs and a new one plugs in.
ICON Motorsports
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
