Car stalls when heat control activated
Old Jan 23, 2004 | 07:47 PM
jocool's Avatar
Car: 89 Iroc & 88 Firecird & 86 Camaro
Engine: 350 TPI & 305 TBI & 305 Carb
I have a 88 firebird and the car stalls if the heat switch is moved from cold to hot at idle. At higher rpms the car just runs poorly. I suspect that maybe it is a vacuum leak, but not sure. I don't want to take the dash off on a guess. Any help is appreciated.
Old Jan 23, 2004 | 07:57 PM
GTA4ME's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 305ci, 5.0L, TPI, HO
Transmission: Borg Warner T5 5-Speed
Axle/Gears: 9-Bolt Positraction Rear w/3.45 Grs
Moving
Old Jan 24, 2004 | 10:41 AM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Definitely a vacuum leak. I'd check the heater control valve (above the pass. valve cover) before tearing the dash out. It's much easier to get to and if it doesn't hold vacuum it could cause that type of problem.
Old Jan 24, 2004 | 08:48 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
friend of mine had a problem like that it. I never figured it out but he ended up replacing the altenator and it never did it again, almost like the energy draw off the motor did it. It seemed to do it only when he moved the control for off - air - vent - heat - df not the one hot to cold. The hot to cold switch has to be a vacuum leak.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Wade787b
Sep 29, 2015 01:15 PM
mustangman65_79
Sep 1, 2015 03:51 PM
TreDeClaw
Aug 14, 2015 06:58 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
