Ok finally got the money for new engine.
Old Jan 24, 2004 | 12:41 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
Transmission: Tremec 3550
Ok I posted a while back with some ?'s about what to buy. I've narrowed it down a lot and just need some opinions on if this is acceptable or if this is just a waste of $$$. I'm running a 350. It has a newly built stock bottom end. I was thinking of getting some 69cc heads (stock). I was gonna get the Comp Cam XE 262H kit.
Specifications:
* Duration at .050 in. cam lift: 218 intake/224 exhaust
* Gross valve lift: .462 in. intake/.469 in. exhaust
* Lobe separation: 110 degrees
* RPM range: 1,300 to 5,600, noticeable idle
A set of summit racing steel roller rockers and a set of stock pushrods from Summit.
I'm gonna put a set of hooker shorties on it, Want long tubes but ground clearance is shot due to the lowering.
I have an Edelbrock 750cfm carb, not sure of model number and an edelbrock performer intake again not sure of specs.
Now I'm not sure about the rockers and the pushrods. I will upgrade if it is required I'm just not sure on that aspect. SO I guess my question is... Will this combo work ok? Will I need a performace ignition? Should I get a new distributor? ANy suggestions?
Old Jan 24, 2004 | 02:41 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
About those summit steel roller rockers.
If they're the ones that look like a stamped factory rocker with a roller on it, look at getting something else. I got a set of those and they were full of burrs in all the wrong places. I sent them back and got Comp.
Old Jan 24, 2004 | 08:04 AM
ede's Avatar
ede
i'd spend a little more and get the comp rockers, only rockers i use. i'd also not run anything from edlebrock, but a lot of people do. check you've geometry before you buy aset of stovck length push rods. why are you replacing push rods anyway?
Old Jan 24, 2004 | 11:33 AM
Fei's Avatar
Fei
Car: 1989 Trans Am
Engine: 94 383 LT-1
No commment on the edelbrock As for the pushrods I'm worried that they may be bent. I was being stupid and not paying attention one day while ajusting the lash on the engine. Well basicly I tightened them down to tight. Broke one and possibley bent some others on the drivers side. Just don't want to take any chances.
corey8084
Sep 17, 2015 02:56 PM
Joniz
Sep 13, 2015 01:28 AM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
buckshot63
Sep 10, 2015 09:15 AM
greenyone
Sep 8, 2015 08:41 PM
