High Voltage on Initial Start Up??
Old Jan 23, 2001 | 10:43 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I have an 86 Trans Am and when I start my car for the first time in the morning, it holds 15 volts!! Does anyone seem to have this same situation! I don't want to call it a problem because it doesn't cause any....I'm just wondering why it does this!
1986 Trans AM
305 TPI
4 Wheel Discs
9 bolt Borg Warner Rear
Completely Stock
Soon to upgrade to a 383 stroker w/TPI, Hedman Shorty Headers, pocket ported 64cc or 76cc heads(undecided), ported intake, comp cam, TPI air foil, Adjustable Fuel Pressure Regulator, possibly bigger injectors!
Current project: Keeping my car running until I get the money for the above mentioned project! :-)
Old Jan 23, 2001 | 10:58 PM
gsmann's Avatar
I have an 86 transam too. it is high when i first start it up in the morning but as i drive it goes down to around 13-13.5 it's been like that for 5 years. so i don't make a big deal about it. well actually i've been through 4 alternators too. but i have a lifetime warranty on mine so i just keep getting them free. it could because of my system too. anyways. don't worry about it.
Old Jan 23, 2001 | 11:15 PM
ronterry's Avatar
Car: '94 Corvette
It's all about thermo resistance.
Latley the temps have been in the teens, and my Vette puts out over 16+ volts when first starting in the morning, and then comes down to around 14.5... It's very normal to have anything between 13-15.5... yea my Vette is putting out some killer voltage in the morning, probably considered outside the norm - but I love it.
You also have to remember that your battery is less effient when cold, so having 15 volts to charge it is good.
Don't worry, most of your electronic are able to take 18 volts without damage.
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Old Jan 24, 2001 | 01:17 AM
burnoutrpm's Avatar
ok anyone who reads my response please!! just ignore it hes my friend and hes righther not watching me type this! any how i need to give him hell for the day so here goes
your car sucks dong you lousy tpi lover!! get a alternator!!! duh!!?? and for intial startup it has no compression left at over 200,000 miles of course it'll start up. also it has a really cool grinding sound in the engine conpartment!haha! sounds like your sawing through the manifold!! it just hilarious!!......like his car!!!!!
anyone else reading just ignore me hes my friend and by right i have to respond to all and every message he posts to give him hell about his car!! hahahahhahah!
1989 firebird formula
Mods: converted from T.B.I. to a carburator 305 to a 350. Flowmater exhaust,hedman shortie hedders,202 heads,350 horse cam,bored.40 over, Edlebrock torker2 and a 600 edlebrock manual choke.
Future mods performer rpm air gap intake (polished) comp roller cam, and way better headsa 400 defintely in the works!
[This message has been edited by burnoutrpm (edited January 24, 2001).]
Old Jan 24, 2001 | 07:20 PM
berlinetta84's Avatar
after reading up on alternators in my service manual because i had to replace it, i think that the voltage regulator is affected by the temperature. it says that it will hold 13.5 volts...less in warm weather. so it may also mean that it bumps it up when its cold. having 15 volts should pose no problem as long as it comes down after the car warms up.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
