how do I get water pump pulley off?
Old Jan 24, 2001 | 11:36 AM
zee28's Avatar
Car: 86 iroc
Is there a strap tool or something to hold the pulley while you loosen the 4 bolts?or is there another way?Its on a 86 LG4 camaro.
Old Jan 24, 2001 | 11:45 AM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
You have 2 options, one is to hold the pulley with your hand and loosen the bolts. (Thats what I did once) and two, is to put the belt back on and then loosen the bolts. Use some liquid wrench if they are stubborn bolts.
Convertible, L98, Mini-ram, ZZ9 cam, Comp Cams 1.52/1.6 steel roller rockers, Trick Flow 23* heads, K&N's with chopped airboxes, March underdive pulleys, Edelbrock ceramic coated TES, Flowmaster cat-back exhaust, Dynomax high flow converter, MAC subframe connectors, Accel box & coil, 3.23 rear gears, white face gagues, and NOS!
When I get back from Kosovo I will be installing these on-order items!
Old Jan 24, 2001 | 11:50 AM
zee28's Avatar
Car: 86 iroc
I tried with the belts on and tight and they slip causing the engine to turn.there is no way I can hold it with my hands.I let it soak last night with some liquid wrench and havnt tried it again.anyone know if one of those strap tools will do it?thanks
Old Jan 24, 2001 | 11:52 AM
zee28's Avatar
Car: 86 iroc
...and I dont have access to a impact wrench.
Old Jan 24, 2001 | 12:21 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Easy. Get yourself a screwdriver and insert it between the bolts as such
\O_O
_O\O
The Os are the bolts, the \ is the screwdriver shaft. With the screwdrivers like that, when you loosen the top right bolt, the rotational forces will be applied to the shaft as it is wedged between the bolts. As in, the top left bolt will be pushing left on the shaft, and the bottom left bolt will be pushing right on the shaft. Hold the screwdriver and nothing moves.
it sounds a lot weirder then it is. If i showed you how to do it you'd say 'damn, thanks, that's easy'
...ed
Old Jan 24, 2001 | 12:26 PM
zee28's Avatar
Car: 86 iroc
what about when i get to the last one?I did try that and the darn screwdriver kept slipping.I will give it another try.I guess once i get one out i can put longer studs in to pry on?thanks
~mike~
1 superclean 86IROC-Z
Old Jan 24, 2001 | 01:15 PM
89ragtop's Avatar
Car: 1989 Camaro Convertible
When they are loose, don't take 'em off. Just leave 'em on so you can still stick the screwdriver between 'em until they are all loose.
Old Jan 24, 2001 | 01:25 PM
Bort62's Avatar
Clamp some vice grips on the pulley, and have fun
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jan 24, 2001 | 03:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I did "sort of" what Bort62 did... I put a c-clamp on the water pump pulley so the clamp would jam against the engine. Same idea, different tool.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Jan 24, 2001 | 05:56 PM
GearHead1973's Avatar
Get a pair of Channellock pliers big enough to grip the outer edge of the pulley ( dont grip it where the belt rides ) this will hold it while you loosen the bolts.
Old Jan 25, 2001 | 02:33 AM
Pat Hall's Avatar
Leave the accessory belt on. Use a wrench and smack it sharply with your hand or a hammer. The quick, sharp blows will usually loosen them everytime, especially considering they're just puny little 10mm bolts. Vice grips are usually my last resort since they love to chew up bolt heads.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
evilstuie
Apr 14, 2016 08:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
