More heads to chose from
Old Jan 22, 2001 | 05:49 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I was just at the edelbrock web site and found their design of the vortec and fastburns\ E-TEC 170 flows 20% more on the exhaust side then the vortecs\ E-TEC 200 outflows the fastburns 10% on the intake and 17% on the exhaust.Both aluminum Just a little info for you guys!
[This message has been edited by e-man (edited January 22, 2001).]
Old Jan 25, 2001 | 09:50 AM
R.O.B.'s Avatar
I just received my e-mail from Edelbrock.
Q:
Do you have any flow data on the E-Tec #6097 heads.
Can these be milled down to 58cc, in order to work on a 305ci?
A:
int/exh
.100 64/54
.200 130/104
.300 186/140
.400 220/169
.500 232/183
.600 238/190
I really do not recommend these on a 305 engine do to the small bore of the
engine.
Why not use on a 305? Isn't these the same thing as Vortec heads that other are using on 305's?
Rob
'86 TA 305 TPI
Old Jan 25, 2001 | 10:25 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The problem with putting good heads on a 305 has nothing to do with flow.
The bore is so small, that if the valves are large enough to support the flows in those sheets, the are so large in diameter that tye no longer fit in the bore. They actually overhang the top of the block. So it is possible, depending on the cam you use and various other variables, for the valves to hit the top of the block. Milling them makes the problem even worse, because it brings the valves closer to the deck.
This is one of the reasons that the 305 just isn't suited for high horsepower applications. It is what it is, and if you want much beyond how it comes, you need to step up to a bigger motor.
ICON Motorsports
Old Jan 25, 2001 | 11:14 AM
R.O.B.'s Avatar
But they are 1.94 and 1.55 valves. Shouldn't these work?
Rob
'86 TA 305 TPI
Old Jan 25, 2001 | 11:47 AM
chevyboy07 91's Avatar
1.94's are close. I've run 1.94's on the 305 head but you gotta do some unshrouding to clear.
Alex (AKA chevyboy) '91 RS 327 stroker, trans-go shift kit>> manual valve body, cat-delete, MSD (ignition, coil, 2-step, timing retard/ advance),Flowmaster, complete Edelbrock suspension including shocks, struts and lowering springs. CRAGAR drag wheels. Lowered 2.25" in front and 1.5" in rear....Best E/T 12.84 @109 mph...(got spray?)plus more!!
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
