Puff of smoke
Old Jan 25, 2001 | 12:19 AM
Pat Westerkamp's Avatar
Puff of smoke
just curious ole bess(1991 Z28 5.7) and she is cherry, but every once in a while, not all the time after she has been run for awhile and then let her sit for about 2-4hrs and go out and start her up she will belch a mostly whit but a little blue cloud I dont quit understand because it does not do it all the time any one have the same thing or any ideas were to start one more if you stroke the engine to a 355 I suspect the chip has to be programmed to the new cam lift and duration fuel timing etc does any one do this that is reputable.
Old Jan 25, 2001 | 11:16 AM
82camaro's Avatar
Car: 82 camaro SC
Most likely if it's a light blue it is the valve seals/guides. Not a problem unless it's using alot of oil. It's common.
355 is a bored 350 not stroked. This is done to rebuild a 350, not for additional power. A new chip won't be required.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Jan 25, 2001 | 01:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
82 is right, the smoke is almost certainly the valve seals, which can be replaced with the heads still on the car. For an experienced person it's about 3-4 hour job from drive-in to drive-out. It's certainly not the kind of problem that requires a rebuild to fix, if everything else about the motor is OK.
ICON Motorsports
db057
Apr 28, 2019 07:45 AM
FormulasOnly
Jul 23, 2018 08:47 AM
tyeo098
Nov 30, 2015 06:27 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
Accerrito22
Sep 5, 2015 09:34 PM
