Interesting problem
Old Jan 26, 2004 | 02:05 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
Interesting problem
I have an 89 iroc 350 tpi that hasn't seen the road in a couple years, im currently making her road worthy and hopefull she will see the road this summer. Anyways, the issue is that she starts up fine and she will run with a fairly good idle (im sure that some sensors, O2 etc. need to be replaced) but overall she runs good. the problem is that after i let her run for a while and then shut her off and then try to start her again, it turns over but will not fire... then if i try to start her up the next day she will start right up again. Im just wondering if anyone had any ideas, Im assuming probobly something fairly simple since she runs fine when she does start, but i cant exactly take her out for a drive if she will only start up once a day, lol. thanks for any input. josh
Old Jan 26, 2004 | 05:14 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
two things come to mind
heat soak on the starter solenoid or the more likely a heated ignition module failing... the ign. module tells the coil to ground and give spark... you can have them tested at your local autozone but heat it up with ah air dryer or have them test it numerous times (give it a chance to heat up cause they are known to work great when cold but fail when warm)
Old Feb 2, 2004 | 07:55 PM
jloshotz's Avatar
Car: 1991 Z/28
Engine: 5.7 TPI
just a thought...if it cranks the second time around but won't start, it's possible your injectors are leaking by and flooding the motor out. After sitting for a long period of time, the flood condition will clear. Just for kicks, Smell your oil to see if your injectors are dumping badly....
~Shotz~
Old Feb 2, 2004 | 10:30 PM
josh1988's Avatar
Car: 1993 Trans Am
Engine: 5.7 LT1
thanks alot guys, its too cold out right now to mess with anything, but I copied both your replies and will get right back on that when it warms up a little.
InfinityShade
Feb 21, 2016 01:29 PM
Mickeyruder
Sep 2, 2015 02:45 PM
g.l.mos
Aug 22, 2015 12:02 AM
overdriv
Aug 20, 2015 03:52 PM
