CTS keeps failing over and over and over...................
Old Jan 23, 2001 | 06:31 PM
irocbsa's Avatar
I have replaced my coolant emp sensor 3 times in the past 12 months. About every 12 weeks I get a code 15. I don't know what is going on. I soldered the connections on the new harness and applied dielectric grease to the sensor plug. This is really starting to get on my nerves. Does the cts wire directly to the ECM harness. Should I replace the entire length of the wire? Could the failures be caused by old, dirty coolant? Thanks.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI, Converted to SD, 700R4, B&M Megashifter, 3.42, Trick Flow Twisted Wedge Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Stall Torque Converter
Old Jan 24, 2001 | 04:06 PM
irocbsa's Avatar
little love here please.......
Old Jan 24, 2001 | 09:54 PM
Vader's Avatar
BSA,
Either you are getting a run of bad or cheaply made sensors (try a genuine AC) or the wiring to the ECM is faulty.
The CTS is wired directly to the ECM, but there is more than one temperature sensor on your engine. One reports to the ECM directly. One is used for the dash gauge (or light). There is another for the secondary cooling fan if you have a dual fan setup. Another is used for the cold start injector control on TPI engines through 1988. Which one are you replacing?
Later,
Vader
"Hand me my bottle of scotch" Ulysses Simpson Grant
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
[This message has been edited by Vader (edited January 24, 2001).]
Old Jan 25, 2001 | 04:30 PM
irocbsa's Avatar
Vader,
Thanks for the reply. I am replacing the one that goes to the ECM directly(the one on the front of the intake manifold). How should I check for faulty wiring. I'm not sure what pin the CTS wires to. I'm running through and integrator due to the switch from MAF to SD.
bsa
[This message has been edited by irocbsa (edited January 25, 2001).]
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
