my tach
Old Jan 27, 2004 | 11:26 AM
91z28350's Avatar
Car: 1991 z28
Engine: 5.7
my tach
hey yal my tach is off by like 1500-2000 rpms when im driving I dont know what would cause this possibly a bad connection? Any input would be appreciated.
Old Jan 27, 2004 | 12:34 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Moved to Tech/General Engine.
Old Jan 27, 2004 | 01:27 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
common problem, they go bad.
when i am racing, i wait for the tach to peg, then give it a good 2 mississippi
Old Jan 27, 2004 | 02:15 PM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
The tach is bad. Mine used to show about 1800 to 2000 rpms at idle. It was the excuse I used with my wife to buy the Z-28 instrument panel with the big speedo. It works like a charm now.
Old Feb 2, 2004 | 07:51 PM
jloshotz's Avatar
Car: 1991 Z/28
Engine: 5.7 TPI
Same trouble in my 91 Z 5.7 Tuned Port car. The Tach worked perfectly until i installed a factory replacement motor. Then suddenly, same problem you guys are having. I was looking through my 1991 chev camaro service manual and it says there is a tach filter in line with the tach to help filter out "spikes and irregularities." It kind of makes sense because I installed an aftermarket Accel coil during the new install. I was going to try eliminating said filter, but i'll be damned if i can find it, even with a detailed schematic..... Hopefully I was of some help here; PLEASE let me know if any of you have any luck!
~Shotz~
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
