Ignition cylinder problems
Old Jan 29, 2004 | 01:13 AM
WaynesIroc's Avatar
Car: 1989 Camaro Iroc-Z
Engine: stock 350
Been having some problems with my ignition cylinder for a while. It has jammed up on me a couple times but I freed it up with some persuasion. About a month ago I was at the Ford dealership(go figure) picking up a part for my sister's 'yota and started the car only to hear the starter still going. Panicked, turned the car off and the starter still ran. Tried like hell to get the battery cable undone so my starter didn't burn up. Finally after a couple of minutes it finally stopped. Got in to start car and nothing. Called somebody, waited a while and she started right up. Must've drained the battery. Recently the cylinder itself has started acting up. Works fine until I try to turn it to the start position. Seems like something is binding up. I can force it to the start position and it will start as usual, but I am getting tired of forcing it. It doesn't do it all of the time though is what gets me.
Old Jan 29, 2004 | 02:21 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
Hope this helps
http://web.camaross.com/forums/showt...hreadid=213823
Same thing happened to me a couple weeks ago
Will
Old Jan 29, 2004 | 06:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Replace the cylinder. Mine started sticking. Since I didn't want to get stuck somewhere I replaced it and all's fine.
Old Jan 29, 2004 | 06:17 AM
ede's Avatar
ede
replace the cylinder it's cheap and easy to do
Old Jan 29, 2004 | 07:56 PM
norcalz28's Avatar
So i replaced almost everything in my steering coumn with stuff off another 89, and it stuck on me again today. I was reay to give up all hope when it turned over like nothing had happened
Will
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
db057
Aug 22, 2015 08:17 PM
Bryan F
Aug 18, 2015 02:28 PM
