Alternator question, (pic inside).
Old Jan 27, 2001 | 05:28 PM
cica55's Avatar
is this part of the alternator supposed to look like that ???
I think one of the "blocks" broke off...
how it happened ? I dunno , alternator worked fine , then I wanted to take it apart , clean and paint the case blue , so I did , and then I saw that there's only one of them , and the other wire looks broken off (it probably broke while I was taking the thing apart although I couldnt' find the broken off piece).
so , should I replace it before I put the alternator back together ?
and if so , what is it called , what's the part number.
PS: if it makes any difference , this alternator came out of a 1985 trans am , LG4.
thanks !
Old Jan 27, 2001 | 05:37 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It definitely won't work like that. The thing that his missing is one of the brushes. You need either a brush set, or the brush holder assy. which includes the white plastic block.
You can get them at most any parts store, for just a couple of bux. Before you put it in, push the brushes all the way in against their springs, and stick a paper clip or toothpick or piece of wire or something through there to hold them in; make sure the thing you use is straight, and leave a little of it sticking through the back of the case, and pull it out when it's all the way together.
ICON Motorsports
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
redmaroz
Aug 16, 2015 11:40 PM
