TB Bypass hose question...
Old Jan 25, 2001 | 02:22 PM
Steve89GTA's Avatar
I used a piece of hose from my removed AIR system. Is this hose good enough for coolant?
Old Jan 25, 2001 | 03:56 PM
Blade's Avatar
Yep
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components, #24 SVO injectors.
Best ET 13.3@107 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Jan 26, 2001 | 01:02 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
You sure about that Blade? I don't recall AIR hoses being more than simple rubber hoses with no reinforcement. Not what i'd call peace of mind for running 15 psi 220' coolant through. I'm not saying you're wrong, i'm just wondering how sure you are. And is it worth the $5 worth of hoses to risk being stranded because of it?
...ed
Old Jan 27, 2001 | 04:43 PM
Steve89GTA's Avatar
Can anyone else comment on this?
Thanks!
89 GTA
305 TPI
WC 5spd w/3.45 rear
Accel Cap & 8mm Taylor's
MSD6A Ignition
Accel Supercoil
Custom Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch
Hypertech Thermomaster Chip
Steel Rad
Cat back 3" Exhaust
HiGh FlOw Dynomax Cat
Old Jan 27, 2001 | 04:52 PM
Guest
Guest
Posts: n/a
Radiator and heater hose is reinforced with nylon thread. AIR hoses are not. Dont do it.
Old Jan 27, 2001 | 06:15 PM
Kevin Irving's Avatar
Car: 1985 Trans Am
I used a piece of 5/8" air conditioning piping to connect the two hoses that were already there.. works like a charm, although it's a tight fit between the TPS and and the alternator bracket.
Kevin Irving
85 Trans Am WS-6, 305 TPI, custom burned '86 PROM with '87 "165"ECM, Accel Supercoil & 8.8 Wires, MSD 6AL, Aluminum Driveshaft, TB Coolant Bypass, Ported Plenum, Modified MAF, Syclone Fuel Pump, JET Airfoil
15.556 @ 86.65mph, Nov 10, 2000.... I know it sucks.. but it will get better!
http://www.geocities.com/transam85tpi/
Old Jan 27, 2001 | 06:52 PM
Blade's Avatar
I did the same thing and used the air hose. Seems good enough to me and never had a problem for two years now...
Old Jan 28, 2001 | 12:38 AM
Bort62's Avatar
I wouldnt Do it, But On the other Hand, that Rubber hose is rated around 75PSi, So in theory It shouldnt Be a problem.
But Hose is Cheap, Dont risk it.
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
$750 L98
Feb 1, 2025 02:25 PM
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
