Reinstalling valve covers.
Old Jan 27, 2001 | 02:54 PM
new87's Avatar
Car: 87Z
Engine: ?
Transmission: A4
I'm tring my damnedest to get my valve covers on. Only it's not working very well, the motor is in the car still. I get the driver side on but it wont seat all the way, and the pasenger side all them wires in the back are make it imposible. Any pointer will be greatly welcome.
87 Z28 305 TPI, Auto, LT-1 cam (peanut is history), 2.73, Gutted air boxes, K & N fillters, SLP Airfoil, Dyno Max 3" cat back, Accel 8.8 mm spirals, Accel cap and rotor, Accel coil, rapid fires, and 170* Stat.
Old Best 15.414 @ 87.47.
Old Jan 27, 2001 | 03:27 PM
ede's Avatar
ede
if they're center bolts i believe the bolts holes are a little off center, if so you may have them up side down.
ICON Motorsports
1st & 3rd
Old Jan 27, 2001 | 05:46 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They have a definite "intake" and "exhaust" side. You probably have it backwards.
ICON Motorsports
Old Jan 28, 2001 | 12:43 AM
Bort62's Avatar
Well, You Got them off, Didnt you ?
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old Jan 28, 2001 | 03:33 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Well I almost resorted to doing this but it seems like you should give it a try. jack up the front of the car on stands and then unplug the pass side coolant temp sensor and the fan stuff that comes off the harness on that side...then you can unhook all the other stuff that plugs in near the top easily and move the entire harness out of the way to get that thing back on. Like I said, I put a hel! of a lot of strain on my wire harnesses to get the cover back on and probably should've disconnected stuff but oh well. Good luck.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: Accel 300+ wires, cap&rotor
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, hopefully engine swap and 4th gen seats in the works...
jerflash
Sep 23, 2015 09:21 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
BOOT77
Sep 5, 2015 03:55 PM
