Valve seals on a 305
Old Jan 24, 2001 | 06:58 PM
DKING's Avatar
My 305 has been fouling plugs about every six months and it gets a funky idle when it is run for a long time. My friend told me that the heads on a 305 leak oil through the umbrella seals. Is that the seal below the spring? How hard is it to replace them? What is involved in replacing them? And how much are we talking here?
Old Jan 24, 2001 | 07:10 PM
ede's Avatar
ede
yeah it's the seal "under" the spring. cost is less than 20 dollars. easy to do with a on the car valve spring compressor and using compressed air to hold the valve up.
ICON Motorsports
1st & 3rd
Old Jan 24, 2001 | 07:19 PM
355 IROC-Z's Avatar
does your car leave a puff of blue smoke outta the exhaust when intially started after sitting for awhile? this is a sign of bad valve seals. are your plugs foiling because of oil deposits or running too rich? do all the plugs look the same?
replacing them isn't too hard really. for in car repair, you must fill the cylinder with air first. then, compress the valve spring and remove the keeps, you can get a tool that uses the rocker stud to compress the spring. if you do replace the seal, i would just get positive seals.
Old Jan 24, 2001 | 08:37 PM
Nordbert's Avatar
Don't laugh, but a friend told me he changed his valve springs on his 440 Mopar
by slipping about ten feetof 1/4" nylon rope
through each sparkplug hole, then turning
the engine with a wrench until the rope was firmly against the valves. Then he removed the keepers with one of those K-D prybar-type
tools and changed the seals and springs.
I have read of this method before, but have
not tried it myself.
I guess it would be safe if you removed the battery cable and put a big sign on the
steering wheel reminding yourself that there
was the better part of a 12 foot rope in the
motor!
Old Jan 28, 2001 | 02:17 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
I've used the 'rope through the sparkplug hole' method myself and it worked fine...just tie the free end of the rope to something that won't fit through the hole; I know someone who stuffed the entire piece of rope into the cylinder....we managed to fish it out with a coat hanger.
Pete
Pete's Place
HiOutput Tech Page
83 SC
203+k mile LG4/5-speed
14.935@94.14
gta90
Sep 15, 2015 04:00 PM
g.l.mos
Aug 22, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 8, 2015 01:18 AM
