SES light, CODE 32
Old Feb 2, 2004 | 08:45 AM
3rdgenstm's Avatar
Car: ‘92 Z28
SES light, CODE 32
SES light came on Saturday while just cruising on the interstate. Went off after I stopped and restarted. Drove it yesterday and it smells like gas, really strong. My clothes smelled like gas. Ran the test and I got a CODE 32. One or all of the following:
1 Barometric pressure sensor circuit
2 EGR diagnostic switch
3 Electronic vacuum regulator valve
I don't know what 1 and 3 are or where they are located. I assume 2 is the EGR valve and that is an easy fix.
No other codes came up other than 12.
Has anyone had this before if so how do I fix? A little help would be appreciated.
Thanks!
Old Feb 2, 2004 | 08:48 PM
Vader's Avatar
On your engine, the error code is for an EGR valve failure to operate. It might not be as easy to "fix" as you presume. The ECM expects to see an increase in MAP when the EGR solenoid is pulsed open. If the EGR valve isn't opening for some reason, the code will set until you repair it or reprogram the ECM for no EGR diagnosis.
This might help get you started:
Old Feb 3, 2004 | 06:17 AM
3rdgenstm's Avatar
Car: ‘92 Z28
Thanks for the diagram. I'll hit it this weekend and see what's up with it.
eightsixseven
Dec 16, 2024 01:50 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
GouldyGTR
Aug 21, 2015 10:43 PM
apie2546
Aug 10, 2015 05:43 PM
Omega
Aug 10, 2015 12:46 PM
