Headlights?
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
Headlights?
Well either my bulb blew out or the whole damn thing went out.
The passenger side headlight went out when in low beam but when I hit the high beams they both work fine. Is it just a bulb or do I have to replace the whole damn thing? Or is it a fuse or something.....
I just did a search for Headlights and read on some post that it is hard as hell and a PIA to change the headlights. Please tell me thats wrong,,,,,it sure looks easy....tell me it is.....
microtech8@triad.rr.com
1987 White IROC-Z
305 TPI LB9 273 Rear Gear
700-R4 auto tranny
97,000 miles
KYB's
Performance Resource Chip
Flowmaster Muffler
Ported/Polished Plenum by "Daniel Burk"
Holley AFPR
Throttle Body Coolant bypass
TPIS air Foil
TPIS MAT Relocation Kit
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
Boush Patinum +4's
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
My Car: http://albums.photopoint.com/j/ViewP...240&p=36621420
[This message has been edited by Wishmaster's87IROC (edited January 27, 2001).]
1987 White IROC-Z
700-R4 auto tranny
97,000 miles
KYB's
Flowmaster Muffler
Holley AFPR
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Boush Patinum +4's
Car: 4
Engine: 6
Transmission: 5
OH NO!!!! Burn it to ashes in a government-approved toxic biological nuclear hazardous waste incinerator immediately!!!
j/k... just the bulb.
ICON Motorsports
ICON Motorsports
I know its the bulb but can I just change the little bulb inside or do I have to change the whole "Big Bulb" you know the square headlight....
how much do they cost?
[This message has been edited by Wishmaster's87IROC (edited January 28, 2001).]
Car: 4
Engine: 6
Transmission: 5
It's the whole big square thing. Takes about 5 minutes, costs about $6.50. Take off the 2 screws on the top of the black trim ring, loosen the 2 bottom ones about 2 turns each; pop the trim ring out; the bulb will fall out; unplug, replug, put the trim ring back on. The only hard part is getting the trim ring back under the 2 bottom screws. Don't take them all the way out if you can avoid it because when you drop them they disappear into Hell and you'll never find them.
ICON Motorsports
ICON Motorsports
Originally posted by RB83L69:
...The only hard part is getting the trim ring back under the 2 bottom screws. Don't take them all the way out if you can avoid it because when you drop them they disappear into Hell and you'll never find them.
I beg to differ. You'll usually find at least one of them embedded in the tread of one of your rear tires. Must be some kind of weird Zen/physics thing, but I seem to find a lot of my dropped screws (and everyone else's) in that manner. So if you're missing a piece of hardware, check there first.
Later,
Vader
"I'm gonna talk about some freaky sheet now..."
Adobe Acrobat Reader 4.0
KaleCo Auto Parts
Well I replaced both of them and it wasnt that hard. Heres a little tip: dont plug the light up before you stick it in the hole, that way you got some room to manuver the clips on the bottom around the screws....
I got the "cool Blues" any problem with those?
Are they way to bright for driving?
I can always take them back..
Car: 1989 Firebird Formula
They should be ok. I just put a set of piaa super plasma bulbs in and they look great. They are kinda expensive, but I really like the way they look. They look a lot better than the hellas I had in there before.
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Check this out:
http://lighting.mbz.org/tech/info/bulb_types/
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
http://www.spinfrenzy.com/stingerssx...easures.html#4
