cam for afr headed 355
Old Jan 28, 2001 | 01:57 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
Looking for a cam for my afr headed 355. It will have long tubes, 190cc AFR heads, 2800 stall, and about 10.5-1 compression. I was thinking about Traxions cam. What do anyone here recommend??
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Jan 28, 2001 | 02:07 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Anyone???
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
Old Jan 28, 2001 | 09:51 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Without a doubt go hydraulic roller.
TPIS' ZZ9 (kinda pricey though) or Lingenfelter's 219/219, which is one step up in duration from the ZZ9. Accel makes a good one too, but I don't recall the number.
CompCams makes several excellent profiles too. Check out their site at CompCams.com
Don't exceed 224 @ .050; shoot for 112 Lobe separation angle and get as much lobe lift as you can. Too much duration causes vacuum problems which won't let your brakes work properly, requires a higher stall speed converter, probably will call for a modified PROM and will make your idle pretty lumpy.
Also you'll want the aggressive (fast)intake ramps like those on CompCams Xtreme Energy Series.
Look for split duration with more exhaust duration than intake, especially if you have a rather restrictive exhaust. Although the 219/219 isn't a split duration profile, guys rave about it.
Of course if I had an idea of how you plan to use the car, I could be more specific. I assumed street performance.
Hope this helps.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Jan 29, 2001 | 12:53 AM
Dan W's Avatar
This should give you some ideas.
http://airflowresearch.com/chevy_dyno.htm
Old Jan 29, 2001 | 09:41 AM
SDC's Avatar
SDC
I'm doing a similar engine, and the cam I'm going to use is the comp-cam #8-305-8. Hyd roller.
-Sean Casey
92 Formula-350
Old Jan 29, 2001 | 12:15 PM
NufNuffZ28's Avatar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Yea.It will be a street/strip engine. Thanks for the help
Chris
1986 305 TPI
8.0 @88 in the 1/8
**Soon to be 355
evilstuie
Jan 9, 2020 08:29 PM
theurge
Aug 21, 2015 12:46 PM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
