Have 1/4 tank of gas that is 1 year old what should I do with it?
Old Jan 29, 2001 | 09:00 AM
Mike86Z28's Avatar
Car: 98 Z28
I didn't put any treatment in it because I thought it would sit for only about 3 months, boy was I wrong. I was thinking on syphoning it out but what if there is residue at the bottom of the tank?
Old Jan 29, 2001 | 09:23 AM
Birmass's Avatar
I would just take out the fuel filter and let it drain out. Then you can replace the filter too. It's on the drivers side under the car by the back wheel.
88 firebird formula
350 Vortec TBI
214int/224exh, .471int/.491exh
Edelbrock headers
SIX-speed
open 3.73's
2 1/4 stock catback
I love pissing those LS1's off
My Formula
Old Jan 29, 2001 | 09:54 AM
LottaBallsCamaro's Avatar
just like Birmass said only dont siphon it, just turn the key to the on position then off, repeast till its out. Dont run it!!! My shop just recently replaced every fuel thing you can think of.
Pretty damn smart with cars for 17!
91 Camaro RS, 305 TBI
No mods yet...Hopefully:
Convert to dual-cat with headers and Borla catback exhaust.
Edelbrock MPFI system.
RAM air hood & Z28 wing.
Z28 cam.
ABS system.
Positraction rearend with rear disc brakes.
Rebuilt front and rearend suspension with polygraphite bushings.
Strutbrace.
Rollbar.
Old Jan 29, 2001 | 10:21 AM
Mike86Z28's Avatar
Car: 98 Z28
My car doesn't have an electric pump, it runs off of a mechanical fuel pump, but I guess I could just unplug the line and get it started (suck on end of hose) or disconnect it at the gas tank and let it drain.
Old Jan 29, 2001 | 11:18 AM
Rylos's Avatar
When I pulled my engine, all i did was let the fuel line of the pump hang down.
Gravity did the rest. In a gas can of course!
Fully restored 84 TA original factory spec (sucks) Mods when the kids grow up "Sigh" no money!
Old Jan 29, 2001 | 12:46 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Fill up the tank and run it. Thats what I do. As long as you have a fuel filter dont worry. Gas may loose some potensey but with fresh gas It'll run fine.
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
BurlyChev
Aug 16, 2015 09:08 PM
kyleb24
Aug 15, 2015 08:24 AM
