which heads would flow better
Old Feb 2, 2004 | 09:28 PM
radiateu2's Avatar
I have a set of 882 and a set of 416 heads to go on a 350. Which heads should I use: the smaller chamber and smaller valve 416 ported and polished or port the 882 and have them decked to decrease chamber size and port and polish them.
Old Feb 2, 2004 | 11:16 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I have an Excel chart with a lot of flow data, if interested post emil address and I will send it to you, however you must have Mircosoft Excel Spreadsheet capabilities.
Old Feb 2, 2004 | 11:22 PM
DTL504's Avatar
Here is some data, but the spread sheet is much better:
CASTING
INTAKE RUNNER
CHAMBER VOLUME
VALVE SIZING
MATERIAL
882
151
76
1.94/1.50
IRON
441
155
76
1.94/1.50
IRON
462
156
62
1.94/1.50
IRON
GM L-98
163
58
1.94/1.50
ALUMINUM
EDELBROCK PERFORMER
166
70
2.02/1.60
ALUMINUM
GM VORTEC
170
64
1.94/1.50
IRON
GM LT-1
170
58
1.94/1.50
ALUMINUM
WORLD S/R TORQUER
170
67
2.02/1.60
IRON
DART IRON EAGLE 165 S/S
165
72
1.94/1.50
IRON
EDELBROCK PERFORMER RPM
170
71
2.02/1.60
ALUMINUM
DART IRON EAGLE 180
174
68
2.02/1.60
IRON
Old Feb 3, 2004 | 12:57 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If that spreadsheet has the 186 castings, ill take it
Stekman@attbi.com
if it doesnt, ill take it anyway
i know F-BIRD'88 and company have had lots of success with the 416 castings (at least i think it was the 416 casting).....do a search, theres lots of good info on the 416 head
Old Feb 3, 2004 | 06:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 416s will flow better, will give you more compression, and will be less likely to crack.
Throw the 882s in the garbage, where they belong.
Old Feb 3, 2004 | 01:23 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Anthing besides 882s!!! lol
Old Feb 3, 2004 | 03:14 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The common published flow specs for 882's are not a stock head as supplied from GM.
And they sure don't perform like that.
In stock form, with the stock valves the 882's flow slightly more than stock 416's,,,but......
In ported form with larger valves the 416 heads come out much better. More flow, better chamber...
You can tweek the chamber size up on the 416's to suite your 350. ( deshrouding) and pick up flow too.
You'll never get the chamber size down near enough on an 882 without $$angle milling$$.
I've had both. The modded 416's are better.
Don't forget the larger valves.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
