Auto Xray
Old Jan 30, 2001 | 04:37 AM
theformula's Avatar
Auto Xray
Basically I need a scan/diagnostic tool to tell me rich/lean condition, O2 sensor voltage, etc..blahblah
Is the Auto-xray capable of this? I'll be using it to tune for part/WOT.
91 Formula
305 TPI 5speed
1LE/G92/WS6
w/GTA gfx,rims,hood
Paxton 10lb blower, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires, fastchip, Bosch O2sensor, SLP headers & catback,short shifter,3:73s w/Auburn posi,160* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Old Jan 30, 2001 | 06:13 AM
MikeInAZ's Avatar
Car: 86 T/A
Engine: 5.0 TPI
The auto x-ray is an excellent tool but it's only as good as the sensors you have on your car. If your sensors are capable of providing the info you need, the x-ray will read them. It will read rich/lean conditions as well as 02 sensor voltage.
I use mine to check for codes, TPS voltage, etc.
Old Jan 30, 2001 | 07:22 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I agree with Mike. The Xray is not only a tool you can use to fine tune your engine, but great for solving driveability problems. It will give you readouts for
Vehicle speed,
Engine rpm,
Airflow (MAF equipped cars),
Block learn,
Integrator,
Knock disable,
Knock retard,
Timing advance,
Coolant temperature,
Air temperature,
Engine run time, &
Injector pulse width
to name a few. I've e-mailed you a spreadsheet that I use at the track to fine tune my engine with the Xray.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
12.57 @ 111 mph.
12.04 @ 114 mph (50-hp nitrous).
http://members.optushome.com/au/downunder1/rides/willie/willie.html
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Linson
Oct 24, 2025 02:00 PM
sp8ty
South East Region
Sep 24, 2018 03:55 PM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Linson
Oct 1, 2015 09:50 PM
