How much lift on stock springs
Old Feb 4, 2004 | 02:34 PM
irocfreak's Avatar
Car: 1986 Iroc-z
Engine: Soon to be 350
Transmission: 700junk4
I have L98 heads from a 91 z28 motor with stock valve springs.
My question is how much lift can i subject them to. Within a safe range.
Thanks,
Dane
Old Feb 4, 2004 | 03:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Any lift at all is too much. THey are garbage. They don't even have enough pressure at the seat, at zero lift.
Old Feb 4, 2004 | 03:09 PM
irocfreak's Avatar
Car: 1986 Iroc-z
Well since he feels so strongly against using them could any one suggest a good valve spring to use on my heads that can support over .510 lift.
Thanks,
Dane
Old Feb 4, 2004 | 03:14 PM
ede's Avatar
ede
comp, lunati, and crane make good springs. i prefer lunati stuff and rb likes comp.
Old Feb 5, 2004 | 12:43 AM
joshwilson3's Avatar
Old Feb 5, 2004 | 05:00 AM
ede's Avatar
ede
springs are springs there is no roller spring or flat cam spring. you need a spring with enough seat and open preasure to match your cam. call comp or lunati and ask about a stock type replacement spring. as for roller rockers i use either the roller tip from comp or the full roller from comp, only roller rockers i'll put on an engine.
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
