centerbolt valvecover conversion kit
Old Feb 5, 2004 | 09:07 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
ok, i'm converting my L98 to 1.6 roller rockers and of course run into the dilemma of having to pay cranecams $300 for a set of narrow-body roller rockers. a ripoff i tell ya. well, i heard that there is an adapter you can buy that will convert your centerbolt heads to receive traditional perimeter-bolt valve covers. anybody know where i can find these? or at least where i could buy a set of narrow-body rockers at a reasonable price?
Old Feb 5, 2004 | 09:25 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
You can get an adapter by Trick Flow at summit. $99 And GM makes another but I think its about $130.
Old Feb 5, 2004 | 09:55 PM
25THRSS's Avatar
you don't need to go through any of that. Just modify your existing valve covers.
Old Feb 5, 2004 | 10:16 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I wouldnt run the cranes. I'd go with teh comp pro mags. they fit under stock cover without mods.
Old Feb 5, 2004 | 10:18 PM
25THRSS's Avatar
You sure about that?
Old Feb 6, 2004 | 12:01 AM
cormyr's Avatar
Engine: 383 miniram
now i realize that the stock valvecovers need to be modified even with the narrow body rockers i believe but isn't the real issue that the standard size aluminum roller rockers won't clear the actual valve cover bolts?
Old Feb 6, 2004 | 12:51 AM
25THRSS's Avatar
I don't think so. I believe they have issues with the supports, not the bolts.
Old Feb 6, 2004 | 12:29 PM
cormyr's Avatar
Engine: 383 miniram
cmon guys i know somebody out there has put roller rockers on their centerbolt heads! tell me what you did and how it worked.
Old Feb 6, 2004 | 12:51 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Yes they fit. Says so on their site and I run them.
Old Feb 6, 2004 | 05:23 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
I used to run a set of Mr.gasket rollers under the stock cover without modification.
Old Feb 6, 2004 | 08:08 PM
25THRSS's Avatar
You have comp pro magnum roller rockers under your stock centerbolt valve covers with no modifications?
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
LittleFranks
Oct 7, 2015 11:26 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
