how do i adjust my roller rockers
Old Jan 30, 2001 | 08:56 PM
bad camaro RS's Avatar
ive adjusted them 3 times and they still seem to be "clicking" at least one is what is the easiest procedure what happens if i get them to tight? or not adjusted right? i have a 87 355 tpi i get them adjusted all seems to be good then a day later i can here one clicking i have poly locks so i dont think they are backing off give me the proper procedure please thanks in advance
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hopeing for 12's
Old Jan 30, 2001 | 10:15 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They adjust the same as any others.
Check very carefully for interference between a pushrod and something else; check especially closely at the inside of the guide plate slots. You may find that one or more pushrods are getting forced up out of their seats in the rockers.
If they seem to be backing off, when you adjust them, turn the nut and the lock screw together to tighten everything fully. You may not be getting the lock screw tight enough by itself with its allen wrench.
ICON Motorsports
[This message has been edited by RB83L69 (edited January 30, 2001).]
Old Jan 31, 2001 | 02:42 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
How much preload are you using.
I always follow the camshaft maker;s recommended preload. The ramps of some cams, especially rollers, are ao aggressive they won't tolerate 1/4 or sometimes even 1/2 turn preload without clicking.
I'll email you the step by step procedure I use to preload my lifters.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
