Oil Questions
Old Feb 7, 2004 | 02:26 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
Oil Questions
ok just curious about a few things with oils
in a car that is burning oil or is designed to burn oil (like mine) which would work better for a lube being induced into the combustion proccess synthetic, dino, or two stroke oil?
how good does two stroke oil lube when it is not being used in a burn situation?
also what is the avg weight for two stroke oils
for dino juice vs synthetic what is the difference in actual viscosity when comparing oils of the same weight
what are problems you can run into when using an oil that has a high content of that stuff that protects agains metal against metal contact... and what is that stuff called again anyway?
which accepts heat better and gets rid of heat (through cooling) a light weight oil or thin weight
and anyone know of a site that goes in depth about differences in oil, testing oils, and all the stats on oils as far as sulfer, ash, viscosity, pour temps and all that stuff?
Old Feb 7, 2004 | 03:08 AM
WishIHadAZ's Avatar
Car: 87 iroc
Engine: L98 350
Alright dude, your sig is hugemongous!
Old Feb 7, 2004 | 06:38 AM
ede's Avatar
ede
www.bobistheoilguy.com
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
