Dyno Results - TBI to TPI
Old Jan 31, 2001 | 10:22 PM
  #51
Vader's Avatar
Originally posted by MrJ:
Have you missed this entire discussion?
I started watching it when it was about real-world dyno results from an induction swap. When it got a little more subjective, I thought I'd throw in some real part numbers to clarify the speculation. Max is close to right. It appears the "mix-'n-match" theory was at play in the early '90s.
Was there something else I missed?
Later,
Vader
"Make Me Bad..."
Adobe Acrobat Reader 4.0
Old Jan 31, 2001 | 10:57 PM
  #52
MrJ's Avatar
MrJ
What Madmax said was, the mix-and-match was in effect for the 80s (some LB9 autos running decent low 15/mid 15 second quarters stock, others stuck in the 16s), but by 1990 GM had settled on the L98 camshaft for use in the LB9.
But about the base gauge package... on a TBI car, your justification makes sense. The gauages reflect the car's capability, and those cars are all speed limited anyways. But on a TPI car, a 120 speedometer and a 5000 tach are moronic and don't reflect the car's capability. Every 1/4 mile run I take, I rev well into redline before shifting... 1-2 at 5300, 2-3 at 5100. I wouldn't shift that high if the car wasn't pulling the entire way
Finally, if you have a 90-92 TPI car, you have 16" wheels. The only speed limited 90-92 TPI cars are Z28s with the 235/55/16 tires and Trans Ams without WS6.
91 Trans Am WS6
Bright White
5.0 TPI auto
Flowmaster 3" 2 chamber catback
Trans Go shiftkit
2000 stall converter
Built on Wednesday
Old Feb 1, 2001 | 01:54 AM
  #53
Guest
Guest
Posts: n/a
I cant help on the GM part number (well... maybe I can but I dont feel like dragging boxes out of my closet to look) but the 85 TPI cam is the L69 cam.
I have a non-G92 91 TPI in my car and it did not have the 'LA' cam in it. MrJ's car is too fast to be a LA cammed car. I guess we need some more proof, but I have a suspicion....
1992rs/ss
Jan 31, 2025 05:10 PM
MustangBeater20
Oct 29, 2022 09:20 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
