Can pulley grooves get so polished from mileage that the belts slip?
Old Feb 8, 2004 | 06:15 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey guys, just curious about this... my '86, with over 264,000 miles on the original pulleys, has always had a hell of a belt squeal problem in the rain. I'll go over a puddle, and the belts get wet, and of course, they squeal. This happens even when the belts are NEW and TIGHT! In the past few years, this has been happening more and more and more in the rain...
So I was wondering... I'm thinking of changing the belts again; it's been a little over a year since the last ones went on. Should I scuff up the pulley grooves with some 100 grit paper? I'm wondering if, since these pulleys are so high mileage, that they're so polished that they're not gripping the belt well. And maybe the slightest bit of moisture on them is causing them to slip.
And I don't want to tighten the belts any more than I have... I almost think I've got 'em too tight as it is!
Thanks for any/all ideas on this!
Old Feb 8, 2004 | 09:33 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I had an Olds 98 with around 180000 miles on it. The only way I ever got the alternator belt to stop squealing was to use a file to rough up the pulley. No more problems after that. I half expected short belt life but the small scratches on the pulley didn't seem to hurt the belt.
Old Feb 10, 2004 | 10:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Great, thanks for the info! I'll give it a try, probably this weekend, and let everyone know how it goes!
Hotrodboba400
Dec 10, 2019 07:07 PM
BDR
Nov 7, 2015 03:05 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
evilstuie
Sep 24, 2015 02:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
