head rebuild on a 1992 RS
Subscribe
Feb 8, 2004 | 10:04 PM
Hello guys,
I want to see if anyone can give me some advice....I just bought a 1992 camaro rs with tbi injection. The car is real quick but puffs white smoke like crazy. I fixed all the body and it is preped to paint but I want to fix the smomke first. Does anyone know how much it is to rebuild heads?? I do have some mechanical knowhow...I can take it apart but IM not sure how to put together the valves and springs. Any suggestions. The engine has about 190,000 miles.
Reply 0
Feb 8, 2004 | 11:02 PM
unless you are going to port and polish the heads it would be worth it to take them to a machine shop. the white smoke could be a cracked head or blown gasket or worse a cracked block. A machine shop could clean them magnaflux for cracks and do a 3 angle valve job It cost me 80 dollars a box of donuts and had 4 guides replaced. If the need to be decked because they are worped they can do that too. There isnt alot that can be done at home unless you have a machinist shop in your house. good luck...The donuts are a great idea.....builds repor and long lasting friendships and a discount now and then.
Reply 0
Feb 9, 2004 | 05:48 AM
machine shop charges around 150 with no parts. seals cost around 20 dollars if you do it yourself.
Reply 0
Feb 9, 2004 | 06:47 AM
I wouldn't put a single penny into those crap heads, if they're still the original ones.
Get a set of 081 heads, off of a 87-up LG4, L69, or LB9. Work those instead.
Reply 0
Subscribe
