is there a big diffrence?
Old Feb 8, 2004 | 11:33 PM
icebird_1981's Avatar
if u had 2 thidgens both with same engine and same mods..everthing the same except one had posi and the other did not, how would a race between them turn out?? what would be the diffrence in seconds in a 1/4 run??
Old Feb 8, 2004 | 11:37 PM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
I would guess that if they were identical down to the gears BESIDES limited-slip and open rear...it would really depend on the amount of power the engine made...the limited slip would be more benificial for getting power to the ground at higher horsepower ratings, but stock I would guess they would run pretty much the same time.
Old Feb 9, 2004 | 12:00 AM
ok lets say both r not stock..both thirdgens had the same mods as i do (in sig). would there be a diffrence? if so by how much??
Old Feb 9, 2004 | 12:10 AM
Car: 1991 Camaro RS
Well, with an open rear and that setup you'd prolly see a good bit of wheel spin and your all around times would suffer...poor 60', higher ET, trap might remain the same or drop a little.
With limited slip I'd bet money you'd see a much better 60' and launch/run all around.
Old Feb 9, 2004 | 05:45 AM
ede's Avatar
ede
it's not something you can quantify in terms of et since you don't know the mods or lack of mods. the posi equipped car shold be quicker in 60' than the non posi car. same would hold true in et at 1320'.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
