What is the displacement of a 350 motor bored .030" over?
I brought my 89 350 TPI block to a machine shop and he said it would be a good idea to bore it .030" over. What would the displacment be? Thanks.
1984 Camaro Sport Coupe - 73K Miles
5.0 Carbed LG4
COMPLETELY stock except for a K&N Air Filter
F41 Suspension Package
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Complete 3" Exhaust System
Aluminum Drive Shaft
3.27 Disc Brake Posi Rear
5.0 Carbed LG4
700R4 Tranny
3.08 Rear End
New Paint
Best 1/4 Mile Run:
16.760 @ 80.74 MPH
Coming Soon:
350 TPI
Transmission: 4L80E/4L80E
No real intent to flame, but this is junior high math.
Volume of a cylinder = area of the base times height.
For an engine, the area of the base = bore, height = stroke. This is the volume displacement, as it's called.
Area of circle = pi times radius squared, or pi x diameter / 4 (pi ~ 3.14159)
For a 350, the standard bore is 4.000". Bored .030" over, it's 4.030. 4.030 squared divided by 4 = 4.060225. Times pi = 12.7556.
The stroke of a 350 is 3.48", so above times that = 44.3894 cubic inches. That's the volume displacement of each cylinder, and there are 8 of them, so the total displacement is 355.11 cubic inches.
Approximately.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, WP 305 heads ported & polished, Hooker headers & y-pipe, hi-flow cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Approximately.
Car: '94 Corvette
If I have a circle that has a 2" diameter.
So the area should be radius square * pi.
I'm coming up with PI. 1 square = 1 * pi = pi
Now with your formula (pi x diameter /4) I'm coming up with 1.57 ???
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
Ron
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
theshackle
Sep 17, 2020 08:26 AM
NinjaNife
Aug 23, 2015 11:49 AM
