Felpro positive valve seals on the exhaust
Old Feb 10, 2004 | 03:09 AM
joshwilson3's Avatar
Old Feb 10, 2004 | 04:44 AM
ede's Avatar
ede
there are positive seals made for exhaust, sorry no PN. i ithnk the next seals i use are going to be teflon.
Old Feb 10, 2004 | 08:05 AM
Damon's Avatar
Assuming the guides are cut the same on the exhaust you can physically slide the same seal on them, too. However, like you, I worry about getting the exhaust guides dried up TOO much, and killing a guide (I have actually had this happen to me). I usually run the posi seals on the intake and a cheap set of umbrella seals on the exhaust.
Old Feb 10, 2004 | 01:27 PM
Old Feb 10, 2004 | 01:35 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I have run the Teflon selas exclusively for years and years on all the motors I build, intake and exhaust. No guide issues here.
Unfortunately they are a somewhat more precision sort of fit than the various rubber ones, and so require machining the guides to a specific size. Not something you can just stick onto an otherwise unmodified motor.
http://store.summitracing.com/partde...CCA%2D503%2D16 The text says "umbrella" over and over, it's wrong. They're not umbrellas.
1992 Trans Am
May 10, 2023 07:19 PM
db057
Aug 22, 2015 08:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
Dialed_In
Aug 20, 2015 01:45 PM
