fuel lines
Old Feb 10, 2004 | 06:48 PM
emtcee's Avatar
Car: 67 camaro
Engine: 383 accel dfi
Transmission: t56
fuel lines
hey guys, i did a search and came up with nothing.anyway i am going to install a fuel injected 383 into my 67 vert and need to run completly new fuel lines.i know what size i need but how do i connect up the fuel lines to each other.i know i can't flare them like brake lines and i've seen the expensive flaring tool for fuel lines.they r going to be steel by the way.obviosly i need a supply and return.are there special fittings or something?(i.e. an fittings?)also i really don't want to spend $500 on just the fuel lines.can anyone give me some advice?thanks....
Old Feb 10, 2004 | 11:22 PM
Vader's Avatar
You can use DOT rated fuel hose and reuseable high pressure fittings. They will adapt to many types of SAE, NPT, and A/N threads, as well as compression for direct fitting to steel lines.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
