Max stroke of a 305
Old Feb 10, 2004 | 03:04 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Max stroke of a 305
Sorry in my previous post i meant to say stroke instead of bore, i got the two words confused.
What is the maximum stroke i can do to my 305 i have right now. I hope one day to get a 383 so if i can use my current engine just with a rebuild kit and a 383 stroker kit, i'll be fine.
Shane
Old Feb 10, 2004 | 03:36 PM
Fast305's Avatar
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
I am going to put a 400 crank and short rods in my stock bore 305 making a cheap 329 engine. This is when I rering the engine.
Old Feb 10, 2004 | 06:13 PM
ede's Avatar
ede
3.75 ought to be easy, maybe even 4
Old Feb 10, 2004 | 06:17 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
so i could amke my 305 a 383???????????
shane
Old Feb 10, 2004 | 06:50 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
you can't make a 383 out of a 305.
and a lot of 305s vary slightly from year to year (according to chiltons) so I'm not sure. But I'd say a 335 is what you get when you stroke a bored 305.
You stroke for power, you bore to clean up the cylinders.
Old Feb 10, 2004 | 06:52 PM
therckid's Avatar
Car: 1986 Trans Am
Engine: 305 LB9 TPI
yeah i finally found this out in the other board.
Hmmmmm.... so all i'll need is a 383 stroker kit, for my LB9(86), to amke it a 383. I think what i'm gonan do then is just bore it out put the 383 kit in, convert it to roller camshaft, and a few other small things. But that'll make the power i want, about 350HP to the rear wheels, with my soon to come MiniRam.
Old Feb 10, 2004 | 08:49 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
No you can't make a 305 into 383 or a 4" bore engine. The max you can bore a 305 is +.06" to 3.796.
Old Feb 10, 2004 | 10:16 PM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
You can make a 350 a 383. But not a 305, as mentioned before.
Old Feb 10, 2004 | 11:46 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
if you could manage a 4" stroke in a 305 that would wind up at 356 cubes (assuming .030 over).
seriously though, go to a junkyard, and pick your self up a 350 block for about $40. you'll thank yourself later.
Jorlain
Oct 8, 2015 01:57 AM
Stryker412
Sep 7, 2015 09:11 AM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 4, 2015 07:11 AM
Formula_88AE
Sep 3, 2015 01:47 PM
