MAP sensor question?????
Old Feb 2, 2001 | 07:01 PM
Crushin91's Avatar
I would really like to know the difference between 1,2, and 3 bar MAP sensors. I have a 91Z (L98). I cracked the housing on my MAP when I replaced the runners and I have to get a new one. Which do I have?? Which should I get???
thanks.....
Hugger Orange '91 L98 Z
Old Feb 2, 2001 | 11:16 PM
Brent's Avatar
You have a 1 bar MAP and that is what you will get when you ask for a MAP for your car at the parts counter. This is the one you want.
2 & 3 Bar MAP's are for turbocharged and supercharged engines. Their voltage output is scaled differently and according to their rating. They will not just plug in and work with the stock ECM code.
Old Feb 2, 2001 | 11:21 PM
Crushin91's Avatar
So is there any difference in the Accel MAP sensor that Summit sells, or are you just paying for the name??
Old Feb 2, 2001 | 11:52 PM
Brent's Avatar
I don't know for sure. My bet is you are just paying for the name. I also bet most MAPs and other sensors are made by a few companys and remarketed by many....
Old Feb 3, 2001 | 02:46 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
Crushin, you didn't like my answer on the TPI Board and had to confirm it here too?
Since Brent said basically the same thing I said at the TPI Board, do you believe us now?
Old Feb 3, 2001 | 02:55 AM
Crushin91's Avatar
Sorry for the double posts! I wasn't sure where to ask? Thanks for the info!!!
9192camaro
16
Feb 3, 2019 12:21 AM
Caspar
Jun 19, 2016 11:19 PM
soarestransam
Aug 24, 2015 08:15 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
squiggy2
Aug 9, 2015 09:30 PM
