L98 and 305 heads
Old Feb 12, 2004 | 05:35 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
L98 and 305 heads
A camaro I am buying has a 90 L-98 vette motor with stock TBI 305 heads on it, I also have a set of 84 416 heads from my 84 trans am, would these be a superior set over the TBI heads, how many CC's are the stock 89 camaro 305 TBI heads.
I've heard the L-98 vettes aluminum heads have 58 cc chambers as do the 416's, and is the later intake hard to adapt for use on earlier heads.
or would a set of f-body 350 heads be my best choice ?
Old Feb 12, 2004 | 08:52 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
The 416s are your best bet. The TBI heads are atrocious
Port and polish the 416s according to the instructions linked at the end of my sig. Lots of good info there
Old Feb 12, 2004 | 04:45 PM
Jproz1167's Avatar
when bolting 305 heads to a 350 what head gasket do you use, I'm thinking a 350 gasket, but correct me if I'm wrong
Old Feb 12, 2004 | 06:54 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You have to use a 350 gaket to clear the 350 bore.
Old Feb 13, 2004 | 04:28 AM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
hmm...confusing statement... doesnt a '90 L98 vette motor have aluminum 58cc L98 heads?
i put in my vote for those heads especially if they're ported. plus they'll relieve your front end of about 50lbs of weight if you ditch the iron slugs.
Old Feb 13, 2004 | 07:38 AM
Jproz1167's Avatar
problem with the aluminum heads is this, while they are the best they also have no provision for a egr system this is a california car so that idea was thought of and shot down as quik
Old Feb 13, 2004 | 10:51 PM
cormyr's Avatar
Engine: 383 miniram
the new gmpp zz4 heads (113 casting) don't have egr or heat riser but the oem production 113 corvette heads did. i believe with c.a.r.b. laws those heads are legal in cali on 85-92 f-bodies and vettes only. if you do decide to go with those make sure theyre the later "d"-exhaust port models. they flow better.
Old Feb 14, 2004 | 06:12 AM
Jproz1167's Avatar
cormyr
the ZZ4 113's are l98 aluminum heads, the vette drew egr gases from the exhaust manifold, at least the 90 L98 did, however I'm not sure about earlier years.
Old Mar 11, 2004 | 03:46 PM
mmcdjs's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 V6
Hey. I've heard that using the 305 heads on the 350 engine were a bad choice, mostly because of the difference in the gap between each CC. using the 350 gasket would leave a small ledge above the bore, and wouldn't that cause turbulence?
lt500r55
Sep 1, 2021 01:30 PM
Jake_92RS
Jan 28, 2020 10:37 PM
CRFred
Feb 7, 2016 11:39 PM
anesthes
Aug 8, 2015 09:37 PM
