Lost my oil cap
Old Feb 12, 2004 | 10:30 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Lost my oil cap
The other day when I was adding oil, i left the filler cap sitting on the radiator and forgot to put it back on . I didn't notice until the car was hesitating and I found the cap still sitting on the radiator. I drove the car like this for 2 days. Did any engine damage result?
Old Feb 12, 2004 | 10:35 PM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
Been there, done that...one time comming home from school i noticed a little smoke behind me as i was almost home...popped the hood once i was home and saw the cap sitting in my spark plug wires and a little oil on the valve cover and headers.
How has your oil pressure been? How much oil is left in the pan??? If you still had pressure or a few qts of oil left you should be ok...
Old Feb 13, 2004 | 12:26 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Just... eliminate your worry and do another oil change and put the cap on at the end
I would not worry unless you lost a lot of oil - which I doubt you did. Just check the level when you do the change.
Old Feb 13, 2004 | 02:16 AM
ddn69's Avatar
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
Ya I did that when I used to have a cutlass. No biggie.
Nate
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
