Removal of molded leather shift handle knob?
Old Feb 2, 2001 | 08:36 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Removal of molded leather shift handle ****?
I'm trying to remove the console plate that houses the ashtray, gear indicator etc. Can't get the **** off. It's not the one with the clip in the back to take out, it's the imitation leather wrapped **** and I have the button off and can't find anything else to detach. Does anyone know how to remove this? Thanks in advance.
Base: 89 Iroc-Z LB9 auto 2.73 posi
Exh: 3" Dynomax muffler, 3" Pipe in place of cat
Ign: Accel 300+ wires, cap&rotor
Fuel: Cleaned and flow-matched injectors, afpr, !air pump&diverter valve
Sound: Clarion deck, Kicker speakers and amps
Suspension: KYB Shocks, BMR Strut Tower Brace
Misc: TB Bypass, Synthetic Oil, Flexlite Transmission cooler,
free mods, hopefully engine swap and 4th gen seats in the works...
Old Feb 2, 2001 | 03:20 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Are you sure? Look again. I had to look twice before finding the clip on mine, they hid it fairly well. I have the same "leather" wrapped ****, and it's held on by a U clip in the front (towards the radio). Pry it out w/ screwdriver. I haven't seen any other way.
If it's not the case, I don't know. If it's round, try unscrewing it?
Old Feb 3, 2001 | 04:14 AM
Pat Hall's Avatar
Another good way to get them off if you do happen to find a clip holding it is to use a hook shaped pick. I have one in my set of cornwell picks, and it worked like a charm. A really thin screwdriver and a little patience prevails as well. P.S. If you don't find a clip anywhere, email this guy and ask him. He's tore apart enough of them to know. His name is Shawn, and his email addy is smiller@bmt.net.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
[This message has been edited by Pat Hall (edited February 03, 2001).]
Old Feb 4, 2001 | 02:24 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
If it's anything like the one in my car, it has a snap-ring under the button, around the shaft of the shifter. I dunno on the newer one, unless they have the "U-shaped" clip.
Good luck!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Block is STILL in shop! (Waiting for my to buy the rods!)
ASE Certified Master Tech
Starting to look like the Kicker poster child!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
